Re: 88-94 to 95-98 All Swap Info Compile
The 95 harness sway is the EASIEST way to go at at. At least in my opinion. How many of you guysreally enjoy your fuse panel hangin around under the dash ? Or your hillybilly rigged heat controls? Or the rest of the crap that gets half assed.
'95's are harder to find around here but i FINALLY got the harness. Its in the back of the ol' pick-up. And heres the kicker .. I put standard in my truck awhile ago and I found a 1995 STANDARD truck LOADED. This truck is exactly what i have build only an ext cab !
So now i have my Standard Tilt Column, 95 harness, 95 computer, clutch neutral switch underhood fuse panel blah blah blah.
95 GMC RCLB Z71 3/4 ton
6" ProComp 3" BL
35x15.50x15 SX's
