Originally Posted by ridered333
well yeah if you can pick up a dana 60 for 15 bucks thats sweet the cheapest i can find them up here is $800 bucks then you gotta dump another 400 or 500 bucks into them for bearrings bushings brakes tierod ends fresh set of hubs cuz might as well do it right the first time
and you're not doing that with the 1/2 ton axle? there's a reason i went through the front end of my 80 when i put the plow on it. the difference in the plow and a 6BT is the fact that i can pull 2 pins, and the plow comes off, so i can still get away with half ton parts, as its not carrying that weight all of the time.
