Old 05-02-2008, 07:08 PM   #4
2500ak
2500ak's Avatar
Member ID: 68421
Re: Push buttons vs. encoder motor
Ok, that wasn't the problem new switch is in same results.
New theory, when the ground failed there were a series of clunks as though the motor was trying to engage 4wd, it didn't, but I think that it might have slipped the gears on the sensor or simply blown out the motor.
If I replace the motor, which is an expensive part, sensor and do you guys think this will fix it. These cases are solid enough that I don't think its the case, and I've never heard of a broken actuator on an nbs.
