Re: Wiring the remote dump on the AVS 9 switch box...
as food for thought, i took the switch box apart, and rewired/soldered that remote dump wire to the fills. avs uses diodes to seperate the individual corners so i jsut switched if from the down to up.. i liked being able to hop the truck up walking up to it..
way i saw it is if YOU are laying out your truck after YOU park it and you accidentally hit the button, no biggie for ups, if you accidentally hit the button for down and your wheels are turned, someones looking under it, door is open by a curb... OOPS
