Re: Wiring the remote dump on the AVS 9 switch box...
you also need to make sure the latching output on that alarm is not negative switched. Different alarms and vehicle manufacturers use different sides of the contact as outputs/inputs. Some are neg while others use a positive output. Not knowing you might fry the circuit with essentially a dead short.
Good judgment comes from bad experience.
A lot of that comes from bad judgment.
