Well my box is finaly dry at the last joint so I figured I would jump on here and show you my single 10 ported box. I had a Prefab box that I used as a guide and I basicly extended it out and made a touch wider. Its not all that pretty right this second and tomorrow my 3" flared port and terminal should be here from partsexpress.
The final specs ended up being External: 22L1 x 20L2 x 20w x 9.25d1 x 6.75d2 useing 3/4MDF.
Internal is :19.25 x 18.5 x 7.5 x 5.25 = 1.31383
+ 1.25 x 7.5 x 18.5(little pie shaped piece)=.05018
Total cuft: 1.36cuft before displacement
AA Arsenal 10 displacement: .12
Port displacement : .045
Arseanal 10 recomended ported box = 1.2 cuft after all displacement tuned to 35hz. Final cuft after displacement on my box 1.195cuft.
Well enoough of the tech crap, here a picture of the box with the Arsenal set in for the pictures. The big hole on the side is the cut out for the 3inch flared port. Yes the hole is huge but this is to accomadate the flare at the end. The smaller hole is of course for the terminal.
So how did I do for my first box build
