its an airline restriction, which will alow you to see how much of the 100psi is escaping. .040" is the metered amount that most testers use. without the restriction, you may as well install this without the rest of the gauge.:
basically, once you pressurize the chamber, the restriction will slow the pressure behind it enough that you'll be able to measure how much of it is escaping.
1977 Chevy K20 - 350/350/203 10/14FF
1980 GMC K2500 - 350/465/205 10/14FF
1992 Chevy C1500 SWB - 5.7/4L60/14SF - totaled 5/9/08
1993 Chevy C2500 - 350/80E/241 10/14FF
1994 Chevy K1500 - 350/60E/241 IFS/G80 10 bolt
