Re: 03-06 Instrument Cluster Stepper Motor Replacement
Soldering is not difficult, any time you buy parts like that any seller will disclaimer because they don't want people trying to return items after melting them with their 120W gun or having somehting not work and try to pass the blame. If you can solder rc stuff then it won't be a problem.
I would start the truck and let it warm up for say 15 minutes so the temp and oil gauges are near center then take a picture with a digicam and print that out. then disassemble the dash, do the work and put the cluster back in with the glass off and start the truck and do the warm up for the same amount of time so the gauges are in the same place then put the needles back on in refernece to the picture.
2004 Silverado ECSB Z71 5.3L 4L60E
Mods So Far: Bug Deflector, Glove Box Light, Floor Courtesy Lamps, Console Power Port, Cobra 25 NW ST WX, Wilson Little Wil, Surepower 120A Battery Isolator and second battery. BFG AT KO 285/75 R16. Ranch cap with Tahoe z71 roof rack.
