Originally Posted by JadXtreme
On my turn signal switch, it has delay windshield wipers, cruise control. The high beam part doesn't work. I can pull it back to turn on the high beams, but the switch doesn't click when I pull it back. Also, when you use the left turn signal, it doesn't come back up after you make the turn. I was wondering what it would take to fix this. I found a new switch for it in the LMC catalog, but the switch for my truck is almost $100. Will the switch w/o delay wipers and with cruise work on my truck? That switch is only $40. I know that there is also another switch that goes inside the column that goes around the column, could that be part of the problem as well? I'm not sure which switch it could be. Please, any advice would be much appreciated.
Replace the turn signal switch that should fix your problem. I just did mine and found the part for 25 bucks.
good luck!
