Re: gm 6.5 vs. 7.3 PSD
Install a manual turbo controller on that 99. Intercooler would be nice too. Need boost, trans, and EGT gauges also. Make sure your boost is correct for you reprogrammed ECM. Make sure the air filter isnt clogged. Install 4" exhaust if you havnt already done so. No cat, no muffler. If your injectors have over 100k on them those could be replaced and may have some benefit too. Make sure the radiator is clean and free of bugs and flushing the cooling system sure couldnt hurt any.
1996 1/2 Ton Suburban 4x2 Gov Lock 3.42 6.5 TD "F" 4L80E 232k
1989 1/2 Ton Suburban 4x4 350 TBI 700r4/208 212k  10 bolts 3.42
1979 1/2 Ton 4x2 Long bed Standard Cab Pickup 454/400 12 bolt 3.07 Unknown miles
