The 7.3 is also Direct injected (most of them anyways) and sprays more fuel right from the factory than the 6.5 does. Most 7.3s also run tons more boost and and intercooler. thediesepage.com did a test and built a 6.5 to comparible specs to a 99 7.3 ford and 99 5.9 dodge and the (automatic) 6.5 actually outperformed an automatic cummins. Cant find that article off hand but here is another one of some intrest.
http://www.thedieselpage.com/finale.htm The indirect injection is supposed to be a setback for the 6.5 but with a performance chip the 6.5 puts out the same amount of fuel as most stock diesels up to around a 2000-ish models and is very comparable in power even with less boost and no intercooler.
1996 1/2 Ton Suburban 4x2 Gov Lock 3.42 6.5 TD "F" 4L80E 232k
1989 1/2 Ton Suburban 4x4 350 TBI 700r4/208 212k
10 bolts 3.42
1979 1/2 Ton 4x2 Long bed Standard Cab Pickup 454/400 12 bolt 3.07 Unknown miles
