Old 05-12-2008, 04:56 AM   #7
daustin
daustin's Avatar
Member ID: 78706
Re: just some questions
The difference in the F and S is the EGR and a slight tuning difference. The 1/2 ton 1500's usually got the S staring in the 1994 model year. The 6.5 TD's are rated anywhere from 210HP ('92-93) down to 180HP (S later models). The F is usually in the 2500/3500's and some Suburbans, lots of people trash the S upper and lower intakes and replaced them with the F intakes. The F intakes don't have the EGR ports and that's blocked off in the lower intake. The F upper intakes aren't tapped for the EGR as well. Hope that helps.
Don
1993 Chevy 3500 6.5TD, 4.10 posi,
3" downpipe, GM-8 13psi max, Round Airbox mod, Straight Exhaust, 4911 turned up 1/4, Boost/pyro/trans instr,
'69 RS Camaro, '68 COPO 427 Vette
