Old 05-13-2008, 08:27 AM   #2
PBA
Member ID: 81820
Re: TH-350 shift point
You have to adjust the downshift cable to get the maximum rpm shift points. For later part throttle shifts, turn the vacuum modulator screw clockwise 1 turn. If still not enough, try a 1/2 a turn at a time till you get the shift points you want. If the engine has good vacuum, make sure that the vacuum modulator has a single red stripe on it.
