Old 05-13-2008, 09:33 AM   #18
dante81_98
You can call me pudro.
dante81_98's Avatar
Member ID: 1090
Re: started bagging my silverado-pics inside
Originally Posted by truecaddytruck
yeah i still have the stock bump stops i was going to mount under the inside of the notch, but it will hit the frame on the ground before the bump stops hit, so its still a waste of time
It is not only NOT a waste of time but it is critical for your frame. If you don't put the bump stop in where it hits the axle as the frame hits then the back will sag down. I know this because mine does that since we did the body drop. I have to add in a bumpstop now that will hit as the body and frame hit the ground.
Click Sig for more information.
