Originally Posted by 92 sierra slx
i know brake fluid will make the chrome peel...rub it with brake fluid scrape chrome off wash sand with some paper and add adhesion promotor and then primer paint and clear it
I didn't know that brake fluid would do that! I have a spot where the pressure washer had starter peeling the chrome off. I think I may try it. I'm thinking about buying the Big Mouth grill to ride with as I do this and swap it out from time to time. That way if I screw it up, I'm not without a grill.
And if you're asking about my rim and tires: 20x8.5 Boss 315's wrapped in Fuzion XTi's 275/60/20. The truck is an 05 Z85 package with no lift yet. The front sits 3/4" lower than the rear. All I did to tuck the tires was cut the front firewall on the passenger side. The tread misses the valence by about 1/4" and lightly scrubs at times on the passenger side during a left turn. Usually good to go.
