Old 05-14-2008, 03:25 PM   #50
Pauly
Status: Online
Member ID: 19647
Re: Gauging interest for aftermarket spider>MPFI conversion manifold
Originally Posted by rob
give me a cast chunk of aluminum that will bolt to vortec heads, has 8 holes for bolts to attach with, and 8 holes for injectors to go i, and some sort of gaping hole in the middle to bolt an air-valve of some kind on to, and I'd be as giddy as a a little school girl.
I can make any TB work, and I can cobble some sort of fuel rails together, please, just PLEASE, someone make a MPFI manifold ALONE, for a set of vortec heads, at the least.
2nd one down would work for you. http://www.edelbrock.com/automotive_...ds_chevy.shtml
peace
Pauly
