Old 05-15-2008, 06:15 AM   #51
atenisplyr
HittingBadPitchesSince82
atenisplyr's Avatar
Member ID: 63845
Re: Gauging interest for aftermarket spider>MPFI conversion manifold
If you wanted to keep everything fairly stock, you would have to make provisions for:
EGR
Thermostat Bypass
Water Temp Sensor
Vacuum Brake Booster
PCV Routing
MAP Sensor
Wiring for Injectors
Throttle Body?
Ignition Coil Bracket Mount?
Not sure if I missed anything. At that point, you might as well go with the marine setup. It has been tried and tested. Although the Edelbrock intake does come with rails.....So that is nice.
'97 GMC ECSB L31: Thorley Tri-Y Headers, 3" Cats, 2.5" True Duals, K&N FIPK, 143db System, AVICN-2, Kinetik 2400, 0 Gauge Everywhere, Full MSD System, HIDs, LS1 Fans, Wheatley Tuned, D/S Maf, No EGR TB Plate, CD/S Rotors
Looking for a ZZ3/4 cam, S10 TC and a nice PCV catch can.
