Re: 16168625 pcm
I have a 93 s10 and a 16168625 and it runs 0D code just the same as a newer pcm. As far as the tranny code for some reason gm put the code for a 700r in even though these pcms only used 4l60s. I don't know if you need the drac input for a 700r or not, you may just need to disable the error code. But I do know that the VSS cannot be directly connected to the pcm.
