Re: 16168625 pcm
Originally Posted by jim_in_dorris
93, I understand that the DRAC isn't part of the PCM, my question revolves around the fact that my 87 VSS signal is generated at the back of my speedo, and supplies the ECM with the VSS signal. With the $0d mask, does it require a DRAC input, or just the VSS signal? Also, I understand that I will have to disable the 4l60E tranny code as I have a 700r4, how difficult is that?
I'm not familiar with the 87 system, but I would say yes, you will need to install the DRAC or a VSSB. Here's a recent thread: http://www.fullsizechevy.com/forums/...cm-issues.html
It doesn't appear to be very hard to disable the 4L60E code. I've tried to help some people in the past with doing this. I don't fully understand it yet, but I would be willing to help. I hope to eventually convert my 91 S10 over to $0D, it has a 700R4.
1993 S10, 355ci.V8, MPFI, 2" TB, 6395 ECM, $0D Mask, TunerCat RT, Datamaster, Comp 280H Magnum cam, Elderbrock Performer RPM heads, 4L60E, 8.8 rear, 8.90s 1/8 mile.
