Re: 16168625 pcm
Originally Posted by neoblood
I have a 93 s10 and a 16168625 and it runs 0D code just the same as a newer pcm. As far as the tranny code for some reason gm put the code for a 700r in even though these pcms only used 4l60s. I don't know if you need the drac input for a 700r or not, you may just need to disable the error code. But I do know that the VSS cannot be directly connected to the pcm.
The 700r4 code is in there for the same reason as the manual transmission code. Some vehicles used these PCMs with both. The 700r4 was used in the early model CPI Astro/Safari vans, running $OD and a 700r4. The manual transmission side of the code was used with the 4 cylinder S10s and the 4.3 TBI 5 spd trucks.
1983 G20 Conversion Van, 310 TPI, 9.5:1 compression, Custom Reed Roller cam, TBI 305 187 Swirl Ports, Doug Thorley Tri-Y headers, dual 3" exhaust, 4L60(1992 700r4), 3.08 gears. 7730 ECM
