Originally Posted by james_8997
o ok well ill check that when i pull the dis. tommorow to put it in time. can i change the gear if its bad or do i need tha whole dis???
Yeah, You'll have to drive out the roll pin from the distributor shaft that holds the gear on. Pull it off and replace. Pretty simple.
