Originally Posted by Pre-Game
love that truck man, i have a question on how you wired the instrument panel, i was planning on doing somehting like that myself.. my cluster went doo doo and nothing works when my headlights are on, so i was wondering if you could help me out on how you wired everything up?
The guages were pretty simple to wire up, The only thing was finding an a.c.c. source for the alternator which I ran mine off of the old abs power source. The main power for them is run off a switch on my switch panel, and the lights are run off of the main headlight switch. The speedo has to wire into the vehicle speed sensor, which is best explained on the autometer instructions. Everything else is simple, the oil pressure is mechanical, water temp is electronic, the tach is wired into the distributor, and the fuel is wired into the sending unit on the cell which is 0-90 ohm, 0 being empty 90 being full. I love having it compared to what I had before, also it is very accurate. Hope that helps.
