Re: Brakes work but pedal sinks if I apply constant pressure
Classic master cylinder failure symptoms. Just give the brake system a good inspect for leaks before you head off to get the replacement master cylinder. Start by checking the fluid reservoir. If that is full then there a probably no leaks. If no leaks are found, then replace that master cylinder with confidence and your problem will be gone.
00 RCSB Z71 / Gibson Super Truck exhaust / Z71 Tahoe valance / EBC slotted&drilled brake rotors, Edelbrock headers, Blackbear tune
Wish List: E-fans, dumped Spintech exhaust coming soon, I'm serious this time
My allergies to these fans... has returned-Slapshot
