05-17-2008, 07:45 AM
#13
Member ID: 77380
Re: 16168625 pcm
Originally Posted by jim_in_dorris
ok, I guess I will need to get the wire harness for the drac out of the S10, then figure out how to wire it up, hopefully it will integrate with my existing VSS, or else I may have to do major surgery LOL. Thanks for the input so far, the 0D code looks a lot better documented than the 747 stuff i have been staring out for months now. I am thinking that I can start with the memcal from the 4.3 and change the injector size and cylinder size and then start from there.
HTH
http://www.jagsthatrun.com/V8-chapte...ed-Sensors.pdf
http://www.jagsthatrun.com/index.html
http://www.tbichips.com/drac/
http://614streets.com/drac.html
http://www.philter.com/cgi-bin/drac.pl
1993 S10, 355ci.V8, MPFI, 2" TB, 6395 ECM, $0D Mask, TunerCat RT, Datamaster, Comp 280H Magnum cam, Elderbrock Performer RPM heads, 4L60E, 8.8 rear, 8.90s 1/8 mile.
