Re: Possible Diesel Combo In 1500
Well I don't know if this will answer anything. But when I helped a friend with his 6bt swap. We used some of the sensors like oil sensor, water temp sensor and I think he used a tuner to delete or disabled a bunch of stuff. But in short he's still using the original pcm. Which basically runs nothing more then the transmission 4l80e. I believe his abs brakes still work as well. So you might be alright there if you can do that.
2007 3500HD NBS Duramax
