This group buy has been run multiple times with huge success each time due to the foam gun's extreme popularity. This is one of the best ways to cut down the time on washing your vehicle, makes washing safer, and makes it really fun too
(and, as tested by another member, can apparently double as a way to wash your dog too, lol) Heres the info!
The proportioners are changed via 15 different sized tips, each with a different diameter opening to allow the soap/chemical to pass through. This allows you to adjust how much or how little solution is used. Most guys are using the green tip. THis is a good starting point and you can adjust from there to suit your needs. Foam guns save time when washing, and allow your solution to start working on breaking up surface dirt and pulling it away before you start to wash w/ your mitt.
Heres whats included and how it works;
Foaming barrel, pistol handle and 48oz container. Simply screw on your pistol handle to any standard garden hose. Pour in your wash solution into the 48oz container. Choose your tip size, and put into base of eductor/barrel, then slide pull hose over it. Screw on the top/barrel. Youre now all set up. Wet down your car, then attach the barrel/container to your pistol handle via quick disconnect. Begin foaming Simple as that
Heres some shots of the new foam gun in use.
Retail pricing is set at 58.99
Your forum discount would put it at 50.15
GB Pricing:
Remember to use your forum discount code (fsc15) to receive the below prices:
Option A: Foam Gun
http://www.glimmerglassdetailing.com/gmfscoption.html
44.88
Option B: Foam Gun, Gallon of Super Slick n Suds
http://www.glimmerglassdetailing.com/gmfscoptionb.html
78.20
Option C: Foam Gun, 32oz Super Slick n Suds, Sheepskin Wash Mitt, 24x36 WW Drying Towel.
http://www.glimmerglassdetailing.com/gmfscoptionc.html
79.26
Option D: Foam Gun, 32oz Optimum Car Wash, Sheepskin Wash Mitt, Foam Core WW Drying Towel, 24x36 WW DRying Towel, Optimum Quick Detailer & Gloss Enhancer.
http://www.glimmerglassdetailing.com/gmfscoptiond.html
101.15
Option E: Foam Gun, 5 Gallon Wash Bucket, 1x Grit Guard, 128oz Super Slick n Suds, 16oz Bug Squash, Bug & Tar Remover, 32oz All Purpose Cleaner (APC), 32oz Bold n Bright Tire Dressing, 32oz Spray n Gloss Quick Detailer, 2x Foam Core WW Drying Towel, 2x Elite Microfiber Towels.
http://www.glimmerglassdetailing.com/gmfscoptione.html
148.75
