Old 05-24-2008, 12:12 AM   #48
Swearingsailor6
Swearingsailor6's Avatar
Member ID: 87350
Re: 700R4 to 4speed manual
every connector that was on the donor truck was burned, so I just tore everything off. I will check to see tomorrow if the old brake pedals had another connector on there. i reused my brake switch, so I know that is hooked up, and I am pretty sure all of the other connectors are connected properly...I don't have a picture, but I could get one tomorrow. It is a connector tword the rear of the column almost up against the fire wall. It isn't the 2 prong that is way at the back, but another one that is a few prongs, maybe 5 or 6 on it.
i guess when the time comes to fire her back up i will check to see what doesn't work, and try to wire trace....maybe i will pull it back apart and double check.
