Old 05-31-2008, 09:03 AM   #4
dave89iroc
dave89iroc's Avatar
Re: Crazy Distributor Gear Wear
look in the dist hole, if the cam gear looks ok, drain the oil, leave the plug out, and dump a couple quarts down the dist hole, and a couple in the fill hole(each valve cover, if possible), then put the plug back in, change filter, then fill, once you get the proper gear for the roller cam, change the oil in about a week, if you are lucky, it will last many more miles
1994 Z71 SCLB 355, Dart Heads, 10.5:1 CR, PM rods, CC XR270HR, CC Pro-Mag RRs, RPM Air-Gap , 4 barrel TBI, 7 qt. oil pan, Headman long tubes , not finished yet
dave89iroc is offline   Reply With Quote
