Originally Posted by Swearingsailor6
Hey It has dual tanks which hold 60 gallons total (says in the glovebox)
if its got 2 saddle tanks under the bed, the glovebox is wrong. the biggest saddle tank you can get is 20 gal, which would be 40 total. GM never offered a Burb/Blazer tank under the rear of a pickup from the factory. you probably misread it.
after putting a South Bend Clutch in my truck, i'm not so sure i want to fool with converting to hydro, though it would be cheaper than replacing the worn out clutch linkage that it currently has.
