Re: how to remove this glue strip for the trim (pic)
use whats in hte above picture. go slow on speed until you get used to it. typically when using the wheel on a drill, aim it so the debris goes down toward the ground. keep it moving becuase it will build up heat quickly and burn the clear.
Dont worry though. its seriously not hard. just do as i said and you'll be fine. go slow until you get used to how it does its thing.
I Refuse To Tiptoe Through Life Only To Arrive Safely At Death....
