Old 06-28-2008, 08:13 AM   #885
outalne94z71
outalne94z71's Avatar
Member ID: 12423
Originally Posted by blazen08
I found an oru sas kit on craigslist in my area for $650 i plan on picking it up wednesday but i want to be sure it will work for my truck. it is designed for the 32.5 spring pad width axle but i dont know much else other than its new in box. oru lists kits on their site "for use with oru dana 60" and "for use with ford dana 60". I am using a high pinion heavy duty dana 44 out of a 78 f250. Am i in luck?
if its just the spring hanger kit then it will work, if its also the crossover steering then you need a flat top pass side knuckle and d44 steering arm
you could also use stock gm parts to hang the springs and be far cheaper
or i have a whole running 94 club cab with a sas i built 9 years ago that im cutting up
