Old 06-28-2008, 08:17 AM   #886
outalne94z71
outalne94z71's Avatar
Member ID: 12423
Originally Posted by Motofalcon
2 - Because my truck is a 98 it has metric wheel studs, but the 60 has american threads, so in order to not have two different sets of lugs, i want to switch the studs to make them match - it doesnt matter if their both american or metric, but i have the front apart now, so it would be easier. will studs from a late 90s ford (prior to unit bearings) fit and be the same metric as my chevy? or are there some american studs available to swap into my rear drum braked 14-bolt?
Thanks.
swap the 14 bolt hubs to older hubs with the 9/16 studs
