Re: Supercharger for my 383
any charger for a 350 vortec from 96-99 will work for your app. Fuel system will be an issue though. The injectors for these engines cannot be upgraded unless you swap in a "marine" intake which has larger injectors. The intake is pricey however and a little fab work is needed but can be done with a some research on the forum.
|97 ext. cab|FIPK|14b SF|Rear discs|4.56's|Tru-Trac|6in SL|35 ssr's|Thorley's|Magnaflow 18"|
Originally Posted by 97Silverado
You are a dumbass....I don't even need to go into why.
