Re: OBS bucket seat alternatives
Originally Posted by tgiannes
so i tried it it did not move easer, gave my self a blister on one of my fingers. tommrow i should spray wd40 on the top of the bolt then some from the bottom let it sit the keep trying, right? Also do i have to worry about stripping the bolt hole/base plate up under the truck, or will the bolt mess up? Thanks
don't worry about stripping it, you can always use a nut and bolt, no biggie, as long as you use a grade 8 bolt
1994 Z71 SCLB 355, Dart Heads, 10.5:1 CR, PM rods, CC XR270HR, CC Pro-Mag RRs, RPM Air-Gap , 4 barrel TBI, 7 qt. oil pan, Headman long tubes , not finished yet
