Old 07-05-2008, 06:21 AM   #305
MStefak
Status: Online
Member ID: 20718
Re: 88-94 to 95-98 All Swap Info Compile
I did every sinlgle wiring sway except then column one (because i switched to the 95 harness at teh same time, and all the splicing was easy.
Being that my truck is standard and has been for years I wanted a standard column but could never find .. but i found a 95 GM ext cab 4x4 loaded .. STANDARD !!!haha. So i took the whole interior and rear truck harness (ie taillights and fuel pump) but the motor part was missing so i took that off a 95 a/t truck and it worked fine. Only thing that needed to be done is jumper 2 starter wires from the tranny of all things.
95 GMC RCLB Z71 3/4 ton
6" ProComp 3" BL
35x15.50x15 SX's
