Old 07-05-2008, 01:16 PM   #48
paw2000
Member ID: 79325
Re: this Intake manifold possibile?
All the different manifolds will work with enough effort applied. I just couldn't see bolting 75lbs on the top of the motor, and with all that mass the additional heat. On a boat thats using raw water cooling, 70 degree water is being circulated and water cooling is much more effective than air to water we use in radiators. There is also a lot more options for throttle bodies for the HSR, and like most hot rodders we all like the glimmer of new,different performance goodies. I was also understanding that boats run a consistent throttle position, usually 3000 rpm after its up on plane. A boat doesn't coast. let off the throttle and is slows down quickly. So a manifold for a boat might be optimized for a particule rpm range and prop size.
96 yukon 4wd 2 dr, 383 stroker, custom cam .595 lift, custom tune, MSD ignition.
