07-09-2008, 11:50 PM
#11
Member ID: 658
Re: 500 rwhp 5.3l
Originally Posted by garrissonj
Man you need to get on a truck site thats more performance based bud like Ls1truck.com or performancetrucks.net anyways pushing 500rwhp outta a stock 5.3 is very doable ill prove it in about 3 weeks  , but just remember the 5.3 only has a 600hp crank shaft, which means you start pushing 600+ HP at the flexplate/flywheel youre gonna rip that bitch apart, im at 400HP at the flexplate 350 to the wheels all on a stock block and stock heads, and im about to squeeze a 200 shot to it, it'll be really close to the 600hp limit but it should be fine. Anyways your cam depends on what youre gonna do. Turbo, supercharged, NOS, N/A, it all depends on what kinda set up you are going to do, all different cams work better for your specific application, like my cam is a good all motor cam but also works well with the juice, anyways jump your ass over to ls1truck.com and ask this question there is an abundance of guys over there that will give you some good info. I mean i could sit here and tell you everything, to get it done, plan on spending at least around $5,000 thats if you do all the work yourself and just shoot the spray to it.
wow... It sounds like you have some learning to do yourself.
Why do you want a twin setup? You could easily attain your goal with a single turbo, and it'll be much cheaper.
08 TBSS
91 HD 3/4 ton
03 Z71 Tahoe
