Old 07-14-2008, 11:45 PM   #54
Pauly
Member ID: 19647
Re: this Intake manifold possibile?
I beleive he means runing a 411 PCM with a custom operating system "patched" into it to allow the 411 PCM to read a 2 or 3 BAR MAP sensor. The stock 411 will only read a 1 BAR MAP sensor.
A higher stall TC is key to a centriguals performance. They dont make good low rpm torque, but make excellent mid/upper rpm power and torque.
peace
PAuly
