Old 07-16-2008, 01:49 PM   #574
dietzster
Member ID: 74974
Re: 96-99 454 Vortec owners?
NODIH, where do you find your injector info? I would like to find a good site that has all the flow rates to compare side by side and know for sure what the actual rates are, not what people think they are, (as you know there is alot of conflicting info on the net). I found those rates on the ls1tech forum and they said the 98's also had 28.8 lb injectors but it would be nice to be albe to type in a part number and find out for sure. Also did you totally disable the TM in your truck, I now have a trans-go HD-2 reprogram kit in my truck and the TM reduced but was thinking of totally getting rid of my TM, I do have a heavy 5th wheel and am not sure if the trans would hold but I can't see why it wouldn't. Let me know your thoughts, thanks
GM Certified Master Tech
Wester's dealer
98 Crew Cab Dually
Vortec 454
4L80-E Trans-go HD-2 Reprogram Kit
Westers Tuned PCM
Thorley Tri-y Headers
True Dual Exhaust
Bored 78mm Xtreme-FI Throttle Body
NBS Power Extending Trailer Mirror Swap
04 Impala SS
Supercharged 3.8L
