Thread: Lean Cruise AFR
Old 07-17-2008, 11:20 AM   #45
MSlewis
Supporting Member
Member ID: 80192
Re: Lean Cruise AFR
Originally Posted by Blue71
I think I have lean cruise working some what without the valve,
But it does not follow the command tables at 4BB4. its always a point leaner AFR then whats commanded. I can see (using DataMaster) it going to openloop on light loads, AF will lean out blms will change. I think it might have some thing to do with the tables at 4895.
Do you mean 4859? I do not see 4895.
