Old 07-20-2008, 08:02 AM   #2
dietzster
Member ID: 74974
Re: mods to 4l80e needed?
I'm in Alberta also, up in Grande Prairie. Call King-o-matic in Edmonton, or there may be one closer to you and get the HD-2 4l80-e reprogram kit, it is good for 91 and up tranny's (don't know what year yours is) and it has a shift kit with adjustable shift firmness and parts to fix every known issue with the 4l80-e also triples holding power in 3rd gear and makes it good for up to like 900hp. Also they have rebuild kits there and ask about upgrading to a 5 pinion planetary, they have all you need to make a very strong 4l80. The stall you want to run will depend on how aggressive your cam is so you'll have to look up the specs.
GM Certified Master Tech
Wester's dealer
98 Crew Cab Dually
Vortec 454
4L80-E Trans-go HD-2 Reprogram Kit
Westers Tuned PCM
Thorley Tri-y Headers
True Dual Exhaust
Bored 78mm Xtreme-FI Throttle Body
NBS Power Extending Trailer Mirror Swap
04 Impala SS
Supercharged 3.8L
