Old 07-20-2008, 09:50 AM   #4
Aloicious
Hired Goon
Aloicious's Avatar
Member ID: 65424
Re: results of the transgo HD2 install
Originally Posted by oldred95
One thing I'm noticing is that the shifts will sometimes be pretty firm and the next time stock like. I believe that is due to the adaptive shift in the PCM that adjusts firmness based on driving style. I've only driven it maybe 15 miles since installing the kit so I will give it some time to see what actually happens.
very well could be, on my 411 PCM it had a ideal 'shift time' where the pcm would try to keep the actual time the transmission takes performing a shift to a specific length of time, and I found that the shift kit made the shifts quicker than the PCM expected, so the PCM would actually try to slow the shifts down, kinda like they were fighting each other, so I disabled that and it helped alot. there were also a few other adaptive parameters that needed changing as well, but I can't recall much right now, I just finished a 14 hour shift, and its bedtime.
'96 ECSB 5.7L, 411 PCM, EFILive V1 self-tuned, LC-1, ZZ4 cam, Custom MPFI w/ 24# Bosch 890's @ 45psi, headers, catback, Detroit Truetrac, 3.73, 1.52 RRs, 75mm TB, sound deadened, DEH-P600UB, Polk comps/10", kicker amps. In the works: T56, Mark VIII fan, distributorless coil near plug setup.
