Originally Posted by NorCal_z71
according to MStefak, if i understood his findings right, since 95 is the first year of the newer dash, last year of the TBI, the wiring is a direct plug and play with the 94 TBI engine and chassis controls, but yet has the newer dash. i just want to make sure that it is all in fact basically plug and play and that if i acquire a 95 dash, with 95 wiring (found one already), that the 95 wiring will plug right in and control the AC system properly via the 95 AC controls which came in the 95 dash. the majority of the dash swaps done have been said to be fairly easy, aside from wiring of the AC controls because the 88-94 apparently used a different configuration basically than the 95-98, thus if you were to just get any other 96-98 dash, no one had yet figured out how to splice the 96-98 AC controls into the 88-94 AC system.
as i had thought though, it seems using a 95 dash and underdash wiring solves this problem, just want to clarify.
Well i asked the same question several pages back and would like to know myself. While im thinking about it, i bought a brand new 95-98 steering column but it seems to be pushed in, do you know how i can extent the column back out?
