Re: rusty cab corners
The problem here is that it's eaten it's way through both the inner and outer panels.To fix it right you would have to patch both the inner and outer.Not very cost effective to buy new parts and use just the bottom little bits.You might be able to find used pieces in good condition but as for the cost I'm unsure.I buoght a rocker section for a 05 a while back and it was 400,for half the rocker.So add that to labor,paint time,etc.It's going to be a good chunk of change.
