Re: more more more power
The total cost for my 383 was $4,500 including the new stroker oil pan to clear the 6" rods, 1.6 stainless steel roller rocker, headers, shortblock built by link below, Patriot aluminium heads, Com Cams roller cam & lifters, reprogrammed ECM and whatever else need to make it run.
Here's an add for M&R
1999 K1500-Int balanced 383, 10:1 pistons,534 lift cam,6"rods,alum heads,1.6 roller rockers,welded alum valve covers,MPFI conv,HD built tranny,custom ECM,HD posi 3.73 gears,13"rear disc,headers,Flowmaster SUV50,highflow cats,drilled/slotted rotors,HID headlight,LED running lights,305-50-20 tires.
