3/4 ton suspension on 1/2 ton
I would like to lift my sierra 1500 2wd using factory parts if possible. i like the height of a stock 2500 2wd with a level kit up fornt. I know the leaf spring in the rear will work but I cant find any info on the front suspension of a 2500. I want to use factory parts for a couple of reasons. a. reliability. b. cheaper sometimes than aftermarket. c. I want to show people how much you can do with GM parts or modifying them. I couldnt find a thread like this anywhere so apology in advance if its somewhere else. Thanks!
I can take anything apart and almost put it back together.
05 Sierra SLE 2WD 5.3 ECSB...modified intake, coolant throttle bypass, drop in K&N
