Thread: 89' interior
Old 07-26-2008, 07:15 PM   #5
kenman1717
Homesick NBer
Member ID: 31582
Location: New Brunswick, Canada(working in Edmonton, AB)
Re: 89' interior
Originally Posted by 89 chevyreddy
newbie here what inner metal piece should i replace?
inner door panel, window regulator is rivited to it as well as the door handle. you need the regulator and door handle setup with rods, with the right manual/power door panel of whatever color for this to work. and the 95 up panels have the holes for speakers. then there is the problem of the door panel not matching the dash, and the little door jamb button not hitting the right pad on the panel for the buzzer/dome light to shut off when the door is closed.
door shells are identical, so they bolt in just fine. the 95+ panels have a small piece covering the mirror bolt access, while the 88-94 panels its all in one.
1997 GMC Sierra 4x4 4.3L 4L60E KOSS CD player,16mpg,3.73 gears z71 skid plates 89 W/T Grille, fender flares coming.
GM trained 2nd year apprentice at a Chev Dealer
