Old 08-04-2008, 10:02 PM   #7
71 CREWCAB
Member ID: 1701
Re: Toe in was @0.17 deg.
15 years of alignments. Spec on those trucks is .10 + or - .10. If you push the button on the machine that says reduce tolerances it will drop the tolerances to .05+or-. Then the display shows red and the tech sells the unknowing customer and alignment because its "out of spec". Ive had to work with several guys over the uears that did that and its sad. .10 off of spec will not make ANY difference. .20 may show up on long term tire wear. .30 will show up fairly early. .02 is a crook trying to take your money. Raise it up and set it back down and it will probably change .02. Ass holes like that make it hard for the honest techs to make a living.
Nick
