Old 08-12-2008, 12:00 PM   #45
gearhed42
Re: Crazy Distributor Gear Wear
Well im sure youve heard of the poppet vavles sticking and also a lot of times the clips break or one side of them breaks and they leak into the intake causing a misfire either way. They have an updated spider unit where they eliminate the poppet valves and have traditional injectors for each cylinder. Im going to pull the distributor today and if it needs to be done im just going to replace the gear because i cant afford any downtime with the truck and napa says they have it in stock. Ill let you know how it goes....
gearhed42 is offline   Reply With Quote
