Re: Crazy Distributor Gear Wear
Ok got everything installed today. The gear from napa was actually right! I marked everything before i took it out. I put it all back together and lined up my marks and she runs but she runs even crappier than before and now theres a check engine light on and absolutely NO BALLS! totally underpowered. So im thinking timing is off. Pulled the plug rotated to tdc yada yada lined up the rotor but where or how do i know where the dist body should be? Is there any way to check timing on a 99. There is no esc to unplug? Now im screwed!
